1 Attachment(s)
Adaptive vault
Hi
I made this adaptive family for vaulted ceiling in the church. It works well but one thing disturbing - it has variable thickness on the sections/ 7 parametres regulate only vertical distance between the curves of top and bottom surface in 7 points. I need to add a formula that connects distance between points and return "normal" distance between curves. Thanks.
Re: Adaptive vault
Welcome to the forum. Is there a reason for modeling the thickness? I would model just the surface, and then, in the project, I would select that surface to create a wall or roof by face in the project. Adaptive points are not necessary, either. Simple reference points hosted by planes are enough.
Re: Adaptive vault
Thanks for advice!
Roof by face is what i need! Why i didn't thought about it before(
I made points adaptive because the chapel with this vaults has irregular hexagon in plan; so every part of the ceiling has different projection.
