1 Attachment(s)
Re: Beam Annotation Tool Bug
I am not quite sure if this is what you are refering, but thought I would mention it. When you click on the Beam tag tool, it will default to tag all beams in the view. What seems to work better is to click on a beam, then click on the beam tag tool. Then it will default to selected beams, and only tag your selection. Also watch for replace existing tags setting.
I was only selecting the new beams I added. Not the "tag all" option.
I selected the individual beam, unchecked the "replaced existing tags" still got the same error.
Is there a way to get this Beam Annotation Tool to save it's defaults? I know it's not that much time to click each box and select the tags each time (as well as setting the offset) However, I want to set this in our template so people don't screw it up.
Yep, just open up your template and set the beam annotation tools how you like. and save. The next time you start a project with that template they will be there!
This is still an issue in my mind.
I don't want to re-tag all the items. I just need to tag a few new beams.
I've used the hide object in view for misc annotation that's outside or on the edge of the view. ie I don't want them to show up in that dependent view.
But if I use the Beam Annotation tool, it un-hides anything that I've hidden. So it causes re-work.
The tool shouldn't work this way. If I only want it to tag one beam, I don't want it to effect the other work in the view.
