Re: Complex structural truss
How is it going to be used in the Revit model? I'm going to guess that you won't be using Revit Structure to do any analysis because you have a Tekla model. If it is a one-off and just for visualization and having the correct shape(s) in all your drawings, then I'd do an in-place family. It looks like you can model most of it as swept blends.
Alternately, if you can't get the forms quite right, I'd ask for an SAT export from Tekla. Then you can simply import it into an in-place family and be done with it.
PS - I assume you understand the underlying geometry of the overall truss, each member, and the complex joints. The reason I ask is that if you are not going to simply import it, it would be a lot easier rebuilding it knowing dimensions, centerpoints, radii, etc. rather than just trying to "trace" the model you posted. As a quick test, I brought it into Rhino to clean it up and export as an SAT. Not knowing the geometry, I started with just trying to draw the top chord's curve and since it has been meshed, it isn't clear that the arcs I was drawing are the actual geometry. If you had centerline curves and the logic of the cross sections and joints, it would be a lot easier to model in any program, Revit, Rhino, whatever. Just a thought.
damon.sidel
The Export to Revit tool that is available in Tekla creates an .ifc file that will import with fairly accurate geometry to Revit.
