4 Attachment(s)
CP336-1L: From Open Paren to Closed Paren: Basics of AutoLISP® in 60 Minutes
Session: CP336-1L
Title: From Open Paren to Closed Paren: Basics of AutoLISP® in 60 Minutes
Instructor: Lee Ambrosius
Course Description: Have you ever looked at some AutoLISP code only to find yourself lost or confused by all the parentheses? Maybe you are not sure if you should even learn AutoLISP? This class helps to take some of the mystery out of AutoLISP as it focuses only on the basics that you need to get started. You will learn how to create a custom AutoLISP file that defines some commands and then load it into AutoCAD®. The routines you will create can be adapted for use in your office. You are not expected to know any AutoLISP at all, and if you do already know AutoLISP this class is not for you.
