All of my toolbars disappeared, how to get them back
Hey all,
I tried to transfer a SINGLE icon from one CUSTOM toolbar to ANOTHER custom toolbar and that worked fine. When I hit apply and closed the customization window. All of my toolbars disappeared !
Default CAD toolbar and everything else. All the menus are loded but no toolbars. It even turned of my Command Prompt. I got that turned back on. I looked through the help files to get info on turn on toolbars and it says, "Just Right-Click on any other toolbar and select the one you want to turn on" THERE ARE NO OTHER TOOLBARS hahahaa
Everything else is working perfect. Just no Toolbars !
Anybody else have this problem.
Thanks !
RE: HELP.. All My Toolbar Are Gone
Originally Posted by robdg
Hey all,
Thanks !
Can you access them through the, erm, I think it's the view menu..
RE: All of my toolbars disappeared, how to get them back
Hi
If no luck with Brenda's suggestion, above, maybe try going with the Command Line version of the Toolbar command ie
Command: _.-Toolbar
Have a good one, Mike
Brenda,
Not sure what ERM stands for...I assume it has something to do the Recovery Manager...
Mike,
the toolbar command from the command prompt worked. I got one toolbar loaded and then just used the right click option to turn on the others.
Thanks !
Sorry, that is my strange way of stuttering over a word...
What I was saying was to check the view drop down menu; which would have given you the option to view a toolbar.
