No multitext or dimensions are appearing in paperspace?
Singleline text is ok, lines in the same multitext layer are ok.
Thnx
Alan_T
Printable View
Thnx
Alan_T
Not a lot of detail to go off of, but the things I'd be looking for is checking the text for their annotation settings to see if they don't include the scale in the paperspace. If they match then probably VP frozen.
Found a temp. workaround by exploding the multiline text to single line text ;)
Still looking for a solution........
@CCarleton
Properties of multiline text:
Paper text height: 100.000
Model text height: 1.000
Paper defined height: 0.000
Model defined height: 0.000
Anotative: Yes (1:100)
And no dimensions from Model space shown in Paper space???
Thnx
Alan_T
I would share a drawing if you can. I might have came off more snide than intended when I called out lack of detail, but in cases like these I doubt anyone will be able to figure it out easily by offering suggestions.
I don't think you came off snide... you are correct, in cases like this, more description is needed and a sample file always helps.
I would bet money (not really) that this is an annotative thing: text styles and/or dim styles don't have the proper scales assigned etc.
It could be a layer thing too I supposed (like layer frozen in the VP).
