Tables turning green - all green
Hi,
I've been having intermittent problems with .xls based tables turning green when selected. It makes them completely uneditable. I doesn't seem to be a common issue as I've only ever seen one other internet post like it - and that was not replied to. The green area extends to well beyond the boundaries of the table and is completely opaque.
I've added a screen capture.
Thanks.
Re: Tables turning green - all green
Hi, I am having the same problem, and also having problems finding any answers on the internet.
Can anyone help?
Most probably that's an issue with the graphics display. Make sure that both the card and the driver are on autodesk's list of certified and supported. Newer driver's may generate newer problems, so stick with the certified version.
I don't think its the graphic card. I recieved a drawing from someone in our office that was having the same problem, so I openend it on my computer and the thick green line is there in that drawing only. I was able to find a work-around by going to the "options" "display" tab and under "display performance" un-check "Apply solid fill"
