Can't restore Alignment Labels
I changed my Alignment Labels to a "No Display" style, and now I can't figure out how to get them back. Normally, I would pick a label which would change the ribbon menu allowing me to change group label properties. If the labels are not displayed, I can't pick one to change the ribbon. Nothing in the Alignment properties allows you to change the group label style. Any Ideas? Or does anyone know the command line name for changing the group label style?
Re: Can't restore Alignment Labels
Pick the alignment and right-click. Choose "Edit Alignment Labels...".
Thanks Jeff, but I wasn't getting that right click option. I found out that it's because the shortcut menus are turned off, and my right click is customized. When I turn the shortcut menus on, then it works. It's a good work around but I'm adding a wish to the Wish List for those of us that don't use right click shortcut menus.
1 Attachment(s)
I like my right-click to to behave like an enter when nothing is selected by I do like the menu when I have objects selected. I've found if you turn on the time sensitive right-click it works just the way I like it. If you have not tried this for our self you may want to give it a try. you are losing a lot of functionality disabling your right-click menus.
Attachment 105467
Thanks Jeff, I'll give it a try.
