Is there a way to apply a type and instance parameter to an object?
Printable View
A single parameter can only be instance OR type, not both at the same time.
However you can have some parameters that are set to instance and others that are set to type. It is very important to get right which one is which.
You cannot use an instance parameter's value in a formula for a type parameter, but you can use a type parameter in the formula of an instance parameter.
...but I'm still not sure what any of this has to do with multiple visibility parameters :/
