I need to move a set of drawings from my local drive to our office server. Is there a way to quickly and easily change where SSM looks for these drawings? I want to avoid rebuilding the sheet set list.
Printable View
I don't believe its an easy fix without involving a 3rd party application. I see JTB World has a Sheet Set Manager Path Edit tool.
https://jtbworld.com/sheet-set-manager-path-edit
Typically I keep the sheet files in the same folder as the .dst -- that seems to minimize my re-pathing issues.
As long as the .dst and the .dwg files stay in the same *relative* location, it should work fine.
For example, if they are like this now:
C:\
----\Projects
---- ----\34567 <--- .dst file here
---- ---- ----\DWG <--- .dwg file(s) here
and you move them to this
\\server
----\share
---- ----\clients
---- ---- ----\Projects
---- ---- ---- ----\34567 <--- .dst file here
---- ---- ---- ---- ----\DWG <--- .dwg file(s) here
It should still work fine. In fact, this is how I *copy* a project now, by picking up the standard drawings and the .dst file and copying them to a new project folder.
