I cant see my imported model.
At one point I need to turn off the visibility of one of my imported revit models links.
I used the VH command to turn it off. Now I want to turn it back on.
I went into the Visibility graphic to turn the revit link back on but I see that it's already checked. I unchecked the box, applied, and then check it back on to see if that might turn the Revit model link back on but I still dont see it.
I'm confused. I also looked under the Models Category but I cant find how to turn the Revit link back on.
What am I missing?
Re: I cant see my imported model.
Type RH, select the link and click Unhide Category.
Hi PijPiwo,
Thankyou for the tip. However, I still cant seem to turn it back on. What step am I missing? I type RH, I unhid the element, then what... is there and enter?
Hi PijPiwo,
The revit link was not hidden by the using the icon that looks like sunglass at the bottom of the screen. It was hidden by the command RH.
You mentioned that it was hidden by VH command (hide category in view). When you type RH (reveal hidden elements – red screen border) you should see your lost (hidden) link, select it and click on Unhide Category on the ribbon, then click on the icon that looks like a light bulb (view control bar) to turn off the Reveal Hidden Elements mode.
…and make sure the link is loaded, maybe it should be reloaded if you don’t see it after typing RH.
Thanks PijPiwo. I finally figured it out
