Adding Parameter to Revision Cloud to create report
I have a need to create a report / schedule (that will stand in as a report) for the revisions I am doing on a set of drawings. What I would like to be able to do is cloud an area that is being revised and then in the Comment field put exactly what revisions are happening in that area. I would like then to be able to create a schedule that has that Revision Cloud's comment field populate the comments for each individual revision cloud on a sheet.
The end result would have a schedule that has the sheet number, sheet name, revision number, and a list of revision comments for each revision cloud on each sheet.
Is this possible? It seems like it would be possible, but I just can't put all of the pieces together. The major piece is being able to list the comments from each revision cloud.
Any suggestions?
Thanks!
Re: Adding Parameter to Revision Cloud to create report
Hi Chris,
This same question has come up several times on our tech support, including yesterday, so we have added access to Revision data to Ideate BIMLink to address this need. Here's a video we made to explain the process, in case it helps.
http://www.screencast.com/t/ZmaNyJAwd
I appreciate the link. I'll give it a look.
I'm sure Ideate BIMlink is a great solution, but is there an OOTB solution that doesn't involve shelling out that much money?
Unfortunately there isn't. This is a wishlist item that hopefully gets implemented sooner rather than later.
