I need to connect this monolithic stair to the floors and I'm not sure how to go about doing that. Can you please help? I have attached a screen shot below
Revit Structure 2012
Printable View
In place extrusion is what I'd do. But I'd do that for then entire stair. Mainly cause I don't like the tool. Make them the same material and they should join together.
Another thing you may need to change is, edit the cast-in-place monolithic properties. change type properties, run type, structural depth.
change this to make the bottom of stair run thicker as required for stair span. The default out-of-box Revit setting is too thin for any stair span.
i create all of my c.i.p. stairs as sweeps. that way i can include\edit any landings or thickened slab edges as required.
