How do I disable Quick Properties?
I have a coworker who's having issues with her Quick Properties. Anytime she clicks on a leader, the quick properties window pops up over the object she's trying to edit.We've tried turning the quick properties off (QPMODE = 0, Ctrl+Shift+P, going through the CUI, toggling it off with Drawing Status Bar Menu, purposely turning it on and then turning it off through the aforementioned methods) and we're both stumped.She doesn't have the QP icon on the status bar, so I'm not sure if that has something to do with it. She doesn't normally use the QP (she prefers the regular Properties window), so we're not quite certain how it was turned on in the first place.
Re: How do I disable Quick Properties?
If it keeps coming back, make sure that she has a workspace active and and she has the workspace setting "Automatically save workspace changes" selected.
Double-checked to be sure that is set to auto save, but it still keeps coming back.
CharcoalWraith
I have a coworker who's having issues with her Quick Properties. Anytime she clicks on a leader, the quick properties window pops up over the object she's trying to edit. We've tried turning the quick properties off (QPMODE = 0, Ctrl+Shift+P, going through the CUI, toggling it off with Drawing Status Bar Menu, purposely turning it on and then turning it off through the aforementioned methods) and we're both stumped.
Have you tried modifying the Quick Properties in CUI Editor, specifically removing the MLeader component altogether?
CharcoalWraith
To display the Quick Properties button on the Status Bar... Right-click on the Status Bar, expand the Status Toggles menu, and select Quick Properties.
BlackBox
This worked! Thank you so much!:D
CharcoalWraith
This worked! Thank you so much! :D
You're welcome, CharcoalWraith; I'm happy to help.
Cheers
