Does any one know how to scale an object different amounts in different directions, not a block. I have a bunch of poly lines that are in a group, the y scale needs to be different than the X, any suggestions without creating a block?
Printable View
Hi
Without going the Block route, take a look at...
_.CopyBase
_.PasteClip (Hint - Look at X & Y Scaling Options).
Have a good one, Mike
Thanks for changing the subject line, I was just about to come and try to do that.
when you say to look at the X & Y scaling options, do I need to be in paste as block? The only option I get with _.PasteClip is insertion point, I click and that is it.
HiQuote:
Originally Posted by ccowgill
No worries... A good, descriptive Thread Title is important to the functionality of the forums.
Have a good one, MikeCode:Command: _PasteClip
Specify insertion point: _X
Specify X scale factor: <Enter Required Value Here>
Specify insertion point: _Y
Specify Y scale factor: <Enter Required Value Here>
Ok, that makes sense, I suppose I could write a quick lisp routine to eliminate a lot of the key strokes,
thanks for the help
I noticed that when I started to write my simple lisp routine, after specifying the scale, 5 for x and 1 for y, when I inserted the paste clip, it scaled 5 both x and y, and upon further review, it appears that is what is happening even without the routine, any suggestions?
HiQuote:
Nope! as it works fine for me at this end (as I showed above).
Maybe post the code you have.
Maybe post an example drawing file that contains the Objects you are trying to Scale differently in X & Y directions.
Attached are the drawing and the code I'll be out of the office tomorrow, so I probably wont be able to reply until Wednesday
HiQuote:
:Oops: Looks like I might have given you a little false information (above)...
Take a look at the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS58723 - Paste entities with non-uniform X and Y scale values
Dead thread resurrection!!! Now that it's been about 13 years, I need to do the same thing, but the solution above no longer works. We're running AutoCAD Civil 3D 2018 and trying to scale linework with Object Data in the X and Y direction but not Z. The problem is when scaling a block in the X and Y direction, then exploding, the Object Data gets wiped out. Also it seems that AutoCAD has "fixed" the option to type "_X" during the pasteclip command, and this no longer works. Does anyone have any ideas on this?
Much appreciated!
