1 Attachment(s)
Extrim
Hi everyone :D
When I run extrim lisp, it appears error at the final step in command bar. Is it Executable?
ERROR;
(; ----- Error around expression -----
(ACET-GEOM-OBJECT-POINT-LIST NA NIL)
;* no function definition <ACET-GEOM-OBJECT-POINT-LIST> ; expected FUNCTION at [EVAL])
Re: Extrim
Calling an Express Tool autoloads other files via acetauto.lsp. If you use extrim from the Express Tools it should work. If you're wanting to use a function from extrim.lsp load it at the start of your routine then call the function. If you're trying to replace the command with one that doesn't require Express Tools you have a lot of code to write.
