Re: Dynamic Revit Elements?
You are half right...
Items such as Walls cannot have variable width components, so you would need to have predefined family types for the various thickness or create types on the fly as you need them.
Doors and Windows are normally created where the size parameter is type based mainly due to perfromance issues. You could create some simple windows and doors etc where the parameters are instance driven. This would allow the window sizes to be changed for each window as required. Please note that generally the width parameter is used as a formula for the rough width type paramater so you would need to remove the formula if adapting an existing family.
many thanks for the reply
