How would I model a wall so that it looks like this in section without having it attach to a slanted ceiling?
This is just an In-place mass.
Printable View
It does not have to be an in-place mass. It could be a wall, with a reveal profile with the shape of a triangle, configured in the wall's properties.
I have never used a wall reveal and for some reason that option is actually greyed out in my Revit.
Edit the Profile of the wall.
Interesting. My options for top constraints are in the wall type ... attach to ... level 1 OR level 2. I don't see where the named (and angled) reference plane is listed so cannot set top to it.
As stated previously: You cannot draw wall sweeps / reveals if you're not in a view showing the wall in its height. So change to a sectional view / elevation / 3d. Then you should be able to draw a reveal in order to cut a shape into your wall:
Attachment 89395
As for attaching to a reference plane: No need to name the plane, but it is good practice. Just make sure you're in a section view of the wall, draw your plane, select the wall, click "Attach Top/Base" and click on the plane ... finished!
Attachment 89396
Thanks. That's clearer now. Attach Top/Base is located in the RIBBON. It is a great feature, where one reference plane could control the tops of multiple walls.
