Top Rails Revit 2013
Is there a problem with the new feature in revit 2013 using the top rails as handrails?
if i model a top rail with 36" aff and 1 1/2" dia and use say floor extension 12" long, it models it but won't show in plan. if i hover over where it should be it then hightlights. if i change the top rail to a regular hand rail then it shows up. what am i missing with this new feature?
this may help...
top rail feature and highlights while editing
http://i1262.photobucket.com/albums/...6/toprail1.png
now it doesn't show
http://i1262.photobucket.com/albums/...6/toprail2.png
if i hover over it with the mouse it shows and selects
http://i1262.photobucket.com/albums/...6/toprail3.png
shown in section it is there
http://i1262.photobucket.com/albums/...6/toprail4.png
why won't is show in plan?
Re: Top Rails Revit 2013
It might have to do with your view range. Not sure, but maybe try messing with that.
i have tried that. if i change the top rail to the way handrails and guardrails were modeled in 2012 and earlier, then it shows up. i was really excited about this feature becuase it has handrail wall extensions returns, floor returns and the P return built into it but you have to use it with a top rail function which i can't get to seem to display....
Try using a Plan Region, and set the View Range differently than the rest of the Floor Plan View and see it it will display. If it displays in elevation/section/3D, then it is a visibility issue in the Plan.
so i figured it out by accident. they are not visible in a coarse view setting, only medium and fine. this has been driving me nuts. regualr rails do not do that!
