I downloaded the ASD 2013 trial version from autodesk .com , after installation and when i tried to open ASD it showed a message saying that liscence has expired ! Any solutions ?Regards
Printable View
I believe you need to Download, Vanilla AutoCAD as well in order for the ASD Trial to Run.
Its a know issue you need to download the hotfix from the Autodesk website. See following link:http://usa.autodesk.com/adsk/servlet...inkID=12952913
There is a fix on Autodesk.com or you can simply reload the the trial version after setting your computer clock/calendar back to Jan 2013. After the install, reboot, then reset your clock :)
