Deleting an overlay does not remove the link to the source file. I'd provide you more but I'm on posting from iPhone.
Printable View
Now that I'm home, here's some additional information:
SourceQuote:
Originally Posted by AutoCAD User Guide, Detach DWF Underlay Files, Concept
Just click on Procedure - same link as you posted, and you'll see that there is no other way to detach underlay objects then through palette "externalreferences"... All I wanted is to try to help (OP has hundreds of dwg files to revise, so without other way to detach - through routine, maybe the best way is to use what can be done, and that is to delete them)... The link to the underlay objects will remain, but he'll be able to see objects that are unlinked entities of dwg...
M.R.
This routine will do the trick, but it overwrites current dwg with new dwg without all underlays... Before using, it is strongly recommended that you make copy of all directories with all dwg files so that originals remain unchanged...
M.R.Code:(defun c:detachall (/ adoc msp dwgname dwgscr scrf)
(vl-load-com)
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(setq msp (vla-get-modelspace adoc))
(setq dwgname (vla-get-fullname adoc))
(vlax-for ent msp
(vl-catch-all-apply 'vla-detach (list ent))
(if
(or
(= (vl-catch-all-error-p
(vl-catch-all-apply 'vla-get-file (list ent))
nil
(vl-catch-all-apply 'vla-get-path (list ent))
nil
(vl-catch-all-apply 'vla-get-imagefile (list ent))
nil
(= (vla-get-objectname ent) "AcDbOle2Frame")
(vla-delete ent)
(vl-cmdf "_.-xref" "D" "*")
(vl-cmdf "_.-image" "D" "*")
(if (ssget "_X" '((0 . "*UNDERLAY")))
(vl-cmdf "_.externalreferences")
(vl-cmdf "_.-wblock" dwgname "Y" "*")
(setq dwgscr (strcat (vl-string-right-trim "dwg" dwgname) "scr"))
(setq scrf (open dwgscr "w"))
(princ "close" scrf)
(princ "\n" scrf)
(princ "Y" scrf)
(princ "\n" scrf)
(princ "open" scrf)
(princ "\n" scrf)
(princ dwgname scrf)
(princ "\n" scrf)
(princ "shell" scrf)
(princ "\n" scrf)
(princ (strcat "erase " dwgscr) scrf)
(princ "\n" scrf)
(close scrf)
(vl-cmdf "script" dwgscr)
(princ)
Hey, I'm not the one with this issue. I'm simply trying to provide accurate information on which a solid decision can be made. If half-right procedures works for you and or the OP, who am I to judge. That just wouldn't fly in my office.
Good luck with that. :wink:
Here is how you can quickly revise whole directory with *.dwg files in it...
Make sure you made copy of whole directory, for files in it will be overwritten...
Add this line to your acaddoc.lsp
copy this file - code (revise.lsp) into ACAD Support directory...Code:(load "revise.lsp")
Start AutoCAD...Code:(defun c:revise (/ adoc msp dwgname)
(vl-load-com)
(vlax-for ent msp
(if
(or
nil
nil
nil
(vla-delete ent)
(princ)
Load this file - code (reviseall.lsp) and start it
After execution of routine, your files in selected directory will be without any underlays attached... You can check this by starting "XREF" command and you'll see that dialog box is now empty...Code:(defun c:reviseall ( / pthfn pth filens fn fnlst)
(setq pthfn (getfiled "Select one file in Folder where DWG files for revision are stored" "/" "dwg" 16))
(setq pth (substr pthfn 1 (vl-string-position (ascii "\\") pthfn 0 T)))
(if (setq filens (vl-directory-files pth "*.dwg"))
(foreach f filens
(progn (setq fn (strcat pth "\\" f)) (setq fnlst (cons fn fnlst)))
(setq revscr (open "c:/revscr.scr" "w"))
(foreach fn fnlst
(princ "open" revscr)
(princ "\n" revscr)
(princ fn revscr)
(princ "\n" revscr)
(princ "revise" revscr)
(princ "\n" revscr)
(princ "close" revscr)
(princ "\n" revscr)
(princ "Y" revscr)
(princ "\n" revscr)
(princ "\n" revscr)
(princ pthfn revscr)
(princ "\n" revscr)
(princ "shell" revscr)
(princ "\n" revscr)
(princ "erase c:\\revscr.scr" revscr)
(princ "\n" revscr)
(close revscr)
(vl-cmdf "script" "c:/revscr.scr")
(princ)
Regards,
M.R. :) :beer:
I would suggest looking into the various dictionaries to see if there is something in there that may relate to this topic. Autodesk has added many new features into AutoCAD via dictionaries.
My variant
Code:(defun C:Detachall (/ *error*
mip:layer-status-restore mip:layer-status-save
delete-xref-img-underlay delete-all-dict
(defun *error* (msg)
(mip:layer-status-restore)
(princ msg)
(princ)
) ;_ end of defun
(defun mip:layer-status-restore ()
(foreach item *PD_LAYER_LST*
(if (not (vlax-erased-p (car item)))
(vl-catch-all-apply
'(lambda ()
(vla-put-lock (car item) (cdr (assoc "lock" (cdr item))))
(vla-put-freeze
(car item)
(cdr (assoc "freeze" (cdr item)))
) ;_ end of vla-put-freeze
) ;_ end of lambda
) ;_ end of vl-catch-all-apply
) ;_ end of if
) ;_ end of foreach
(setq *PD_LAYER_LST* nil)
) ;_ end of defun
(defun mip:layer-status-save ()
(vlax-for item (vla-get-layers
) ;_ end of vla-get-layers
(cons (list item
(cons "freeze" (vla-get-freeze item))
(cons "lock" (vla-get-lock item))
) ;_ end of cons
*PD_LAYER_LST*
) ;_ end of cons
) ;_ end of setq
(vla-put-lock item :vlax-false)
(if (= (vla-get-freeze item) :vlax-true)
(vl-catch-all-apply
'(lambda () (vla-put-freeze item :vlax-false))
) ;_ end of if
) ;_ end of vlax-for
) ;_ end of defun
(defun delete-xref-img-underlay (/ count txt)
(mip:layer-status-save)
(vlax-for Blk (vla-get-Blocks
) ;_ end of vla-get-Blocks
(if (and (= (vla-get-IsXref Blk) :vlax-false)
(not (wcmatch (vla-get-name Blk) "*|*"))
) ;_ end of and
(progn
(setq count 0
txt (strcat " Erase Xref and Underlay in "
(vla-get-name Blk)
) ;_ end of strcat
) ;_ end of setq
(grtext -1 txt)
(vlax-for Obj Blk
(setq count (1+ count))
(if (zerop (rem count 10))
(grtext -1 (strcat txt " : " (itoa count)))
) ;_ end of if
(if
(and (vlax-write-enabled-p Obj)
(or
(and ;_ XREF
(= (vla-get-ObjectName obj) "AcDbBlockReference")
(vlax-property-available-p Obj "Path")
) ;_ end of and
(and ;_ UNDERLAY
(wcmatch (vla-get-ObjectName obj) "*Reference")
(vlax-property-available-p Obj "UnderlayName")
) ;_ end of and
(= (vla-get-ObjectName obj) "AcDbRasterImage") ;_ IMAGE
) ;_ end of or
) ;_ end of and
(VL-CATCH-ALL-APPLY 'vla-Delete (list Obj))
) ;_ end of if
) ;_ end of progn
) ;_ end of if
) ;_ end of defun
(defun delete-all-dict (dict)
;;; dict - dict name (like "ACAD_IMAGE_DICT", "ACAD_PDFDEFINITIONS" ... )
(vl-catch-all-apply
'(lambda ()
(vlax-map-Collection
(vla-item
(vla-get-dictionaries
) ;_ end of vla-get-dictionaries
dict ;_ "ACAD_IMAGE_DICT"
) ;_ end of vla-Item
'vla-delete
) ;_ end of vlax-map-Collection
) ;_ end of lambda
) ;_ end of defun
(vl-load-com)
(delete-xref-img-underlay)
(command "_-xref" "_d" "*")
(while (> (getvar "CMDACTIVE") 0) (command))
(mapcar 'delete-all-dict
(list "ACAD_IMAGE_DICT"
"ACAD_DWFDEFINITIONS"
"ACAD_DGNDEFINITIONS"
) ;_ end of list
) ;_ end of mapcar
(command "_.regenall")
(command "_.externalreferences")
(princ)
) ;_ end of defun
After, attaching *.dgn, and then detaching it either using XREF dialog box, or azarko code, I still have layers definitions of unreferenced *.dgn only visible through "PURGE" command... It is impossible to delete them in same session with (command "purge" "a" "*" "n")... Only when I save this, empty of dgn, dwg file, close it and reopen, then I loose this definitions... My variant with command wblock, close and reopen, seems to does just that what is needful for getting rid of these unreferenced layers...
M.R.
See attached *.zip and check what I meant...
