Re: Get values from xdata
Hi,
Try this:
(foreach x (cdr thexdata) (if (= (car x) 1000) (setq lst (cons x lst))))
Using (foreach x (cdr thexdata) (if (= (car x) 1000) (setq lst (cons x lst))))
I got this:
((1000 . "#TP=7") (1000 . "N=325") (1000 . "#HG=211.000") (1000 . "#TE=20181209.1429") . "")
or for other point
((1000 . "#TP=5") (1000 . "#TE=20181210.0029") (1000 . "N=124") (1000 . "SGN=tree") . "")
How to get variables TP, TE, N, SGN, HG and their values?
Hi,
I don't have any example drawing of your Xdata so please try the following and upload a sample drawing to check the objects' data before posting codes and to save time.
(if (and (= (car x) 1000)
(setq p (vl-string-search "=" (setq v (cdr x))))
(setq s (vl-string-left-trim "#" (substr v 1 p)))
(setq l (cons s l))
If that works as expected then just use the reverse function to reverse the order of the return strings.
Not sure about this was trying to find another example may be usefull.
(defun c:test ( / ent vals x codes datas)
(setq ent (entget (car (entsel "select an object"))))
(vla-GetXData (vlax-ename->vla-object (cdr (assoc -1 ent))) "" 'codes 'datas)
(if (/= datas nil)
(progn
(setq vals (vlax-safearray->list datas))
(repeat (setq x (length vals))
(princ (strcat "\n" (setq val (vlax-variant-value (nth (setq x (- x 1)) vals)))))
(alert "Please pick again object has no xdata")
A start with this?
((lambda ( / js n obj elist xd_list)
(setq js (ssget '((-3 ("*")))))
(cond
(js
(repeat (setq n (sslength js))
(setq
obj (ssname js (setq n (1- n)))
elist (entget obj (list "*"))
xd_list (cdr (assoc -3 elist))
(foreach el xd_list
(print (car el))
(mapcar 'print (mapcar 'cdr (cdr el)))
(print)
(prin1)
All three codes are great, I got what I want, so thanks to Bruno.Valsecchi, Tharwat and BIG-AL.
In Tharwat's code I have added:
(setq val (substr v (+ 2 p) 15))
(cond
((= s "N")
(setq N val))
((= s "TP")
(setq TP val))
((= s "HG")
(setq HG val))
((= s "SGN")
(setq SGN val))
((= s "TE")
(setq TE val))
(t nill)
); cond
to get values. Probably this is dirty coding but it works for me.
Next I would like to ask you friends is how to pass variable to xdata?
For example:
(setq PtNo (getstring "\nPoint indicator: "))
(setq PtType (getint "\nPoint type: "))
(setq PtHgh (getreal "\nPoint height: "))
If I use:
(command "POINT" (setq NPt (getpoint "\nPoint coordinates: ")))
(setq lastent (entget (entlast)))
(regapp "MY_APP")
(setq N (cons 1000 PtNo)
TP (cons 1000 PtType)
HG (cons 1000 PtHgh))
how to add N, TP and HG to entity lastent as extended data to be like
(-3 ("MY_APP" (1002 . "{") (1000 . "#HG=311.7700") (1000 . "N=147") (1000 . "#TP=4") (1002 . "}")))
Thanks again, best wishes
Hi,
You can append the xdata to a certain object as follows based on your posted example;
(and (/= "" (setq PtNo (getstring "\nPoint indicator: ")))
(or (tblsearch "APPID" "MY_APP")
(regapp "MY_APP")
(setq obj (entmakex (list '(0 . "POINT") (cons 10 NPt))))
(setq zin (getvar 'DIMZIN))
(setvar 'DIMZIN 0)
(setq PtHgh (rtos PtHgh 2 4))
(setvar 'DIMZIN zin)
(entmod
(append
(entget obj)
(list
(list -3
(list "MY_APP"
'(1002 . "{")
(cons 1000 (strcat "#HG=" PtHgh))
(cons 1000 (strcat "N=" PtNo))
(cons 1000 (strcat "#TP=" (itoa PtType)))
'(1002 . "}")
That is all I need for now, I can continue now on. Thank you very much Tharwat you have made my life easier. Thanks to Bruno and BIG-AL too.
BaneBax
You're welcome anytime. ;)
