Rép. : Re: trellis with a vine
I advise you to add them on your rendering with photoshop
For your elevations, you can easily create light png files and insert them on revit.
Re: Rép. : Re: trellis with a vine
Unless you export to 3dsMax and acquire some decent vines off turbosquid or something, best to stick with photoshop on this one. OR create the best ever decal of what you want and render it in Revit as an decal image in your view! ;)
rbcameron1
it's actually fairly doable now with adaptive components. Create a section of vine with 'x' number of leaves and a 3 point selection to handle arcs/angles. It will be heavy as all can be if done realistically, and not really recommended, but it can be done.
Yeah, I have a very intense model that uses some of those adaptive curtain wall spider connections. I even have a high-end computer and it drags and drags when any decent components are used. Granted, it can be controlled through visibility settings but still....I'd like Revit to be able to handle geometry better. Strange since I put that file into 3dsMax and there is essentially no drag at all.
