Install Problems - Microsoft Visual C++ 2010
Hi Guys,
Not sure if anyone else has run into this yet, but i've now had this happen on a few installs of various Autodesk Software. The install fails to complete because there is a newer version of the C++ 2010 Redistributable on the machine - the installer isn't smart enough to by default ignore this...
Microsoft Visual C++ 2010 Redistributable Setup - Installation Log
Installation Blockers:
1.A newer version of Microsoft Visual C++ 2010 Redistributable has been detected on the machine.
Global Block Checks: StopBlockers evaluated to true.
Final Result: Installation failed with error code: (0x000013EC), "A StopBlock was hit or a System Requirement was not met." (Elapsed time: 0 00:00:00).
Revit install INI file:
[VCREDIST2010X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2010 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2010\vcredist_x86.exe
EXE_PARAM=/q /l %temp%\vcredist_x86_2010.log
VC_FUNC=VCx86RedisCheck
VC_PARAM={196BB40D-1578-3D01-B289-BEFC77A11A1E}
VC_SOURCE=Setup\SetupUi.dll
PATCHES=
Because the C++ 2010 fails to install the whole install process fails due to the requirements for installation not being met. If you add IGNORE_FAILURE=YES to the grouping i.e.
[VCREDIST2010X86]
PLATFORM=ALL
PATCHES=
IGNORE_FAILURE=YES
It will allow the install to complete but you run the risk of the installation continuing if it does actually fail for other reasons other than a newer version being detected on the machine.
Re: Install Problems - Microsoft Visual C++ 2010
I had a similar issue (same?) where Revit failed to install. But what I discovered was that C++ version wasn't responsible since uninstalling whole C++ and reinstalling did not help me.
In fact it was/is a bug in install setup for 2013 products where if you made ANY changes in Setup options your installation would fail.
So if you have this problem try not modifying any option during setup and just install. That helped me. But my templates were not installed properly.
Reason being, Autodesk had some problems with their Template Server and specific templates (it's been fixed now). Hope it helps someone.
Yeah i had the same problem with the content servers also.
The c++ problem above is a different problem, it's not Autodesk specific. There is a fair bit about it online for other software programs.
I haven't had the issue of modifying the deployment ini file causes the install to fail, i've tweeked them a bit to work inside our corp environment.
