Taking Sheet Sets out of the "Recent Drawings" list
Hello,
I'm in civil3D 2010
Not sure why but my "recent documents" is always filled with a list of sheet sets I have opened. This makes it pretty useless to me, as I ussually like to open a single dwg. Is there a way to make sure the sheet sets don't get into the "Recent Documents" list on the ribbon?
Thanks
Re: Taking Sheet Sets out of the "Recent Drawings" list
Not that I'm aware of. If you don't find a way to do it, you could pin the drawings you often use to the list and that way they never "fall" off the bottom.
http://forums.autodesk.com/t5/AutoCA...st/m-p/2329115
And naturally, this bug is still in the 2011 release. That makes three years of a non-functional recent docs list... :roll:
Brian Hailey
I think I just have too many to pin, and then I know I would forget to unpin them. I generally work on 4 to 5 different projects with up to 10 different dwgs a piece. I would just make a mess out of it. lol
In that case, the recent document list may not be the best solution, even without the sheet set issue. When you go to open a drawing, drag the folder where you drawings reside over to the left hand side and it will place a shortcut to that folder there.
