When I initiate the qselect command I receive the error in the title. I tried to dview, selected all objects, then typed off, still same error. What else can I do?
Printable View
Hi
Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
ID: TS21997 - Switching between parallel projection and perspective view mode
ID: TS17740 - Cannot draw objects or zoom after exiting 3DORBIT command in perspective view
Have a good one, Mike
Those didn't help.
Hi
From what you've described it sounds like you need to turn OFF Perspective View.
If you are doing that and still experiencing the issue/problem can I please suggest that you post the drawing file here (I assume Rightly or Wrongly this issue/problem is occurring within *only* one drawing file) so we can take a look.
here is the dwg it 2000i format.
again, the prblem is when I want to go into qselect.
thanks.
Hi
Please find attached "QS_Problem_Fix.dwg", you should now be able to use ._QSelect within this drawing file.
Below is what I done to correct the drawing file -
Command: ._Dview
Select objects or <use DVIEWBLOCK>: _All
2027 found
1 was not in current space.
Enter option
[CAmera/TArget/Distance/POints/PAn/Zoom/TWist/CLip/Hide/Off/Undo]: _PO
Specify target point <1303549.211, 429745.035, 1.048E+99>: 0,0,0
Specify camera point <1303549.211, 429745.035, 1.048E+99>: 0,0,1
Enter option
Regenerating model.
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS59340 - Plot or preview shows incorrect area of drawing when plotting limits
That fixed it.
thanks mike
