Thread: .CTB File Locations
    2005-06
    27
    Default .CTB File Locations
    Hello,
    I am hoping some one out there might be able to help me.
    I have just installed AutoCAD 2010 and I cant seem to find the location to add my own .ctb plot files.
    Below is the path where the plot styles are found for AutoCAD2009.
    C:\Documents and Settings\All Users\Application Data\Autodesk\ACD-A 2009\enu\Plot Styles
    But in this new release there is now application data folder present.
    Can some one please point me in the right direction...
    Thanks
    Niall.
    Houston
    7,519
    Default Re: .CTB File Locations
    You can find your path here:
    Options>Files>Printer Support Path>Plot Style Table Search Path
    2005-06
    27
    It s cool,
    I went into options, looked at my support file locations and I found what I was looking for.
    In this release the path is different:
    C:\ProgramData\Autodesk\ACA 2010\enu\Plot Styles
    2007-06
    Chesterfield, MI
    378
    You can also define your own path to all of your support files by modifying the paths that you see under "Options > Files" (part of the step that was mentioned by rkmcswain). For more information on this do a search for "support" under Help.
    This is very handy if you need to host the support files on a network so you can share them with other users. For more information enter Options in Help and browse to the section that addresses the Options Dialog Box.
  1. Replies: 19
    Last Post: 2007-10-17, 03:11 PM
  2. File Locations
    By tmomeyer in forum Revit Architecture - General
    Last Post: 2007-09-05, 12:31 PM
  3. XML file locations - Network
    By Thomas Maleski in forum Revit MEP - General
    Last Post: 2007-08-22, 03:26 PM
  4. Backup file locations
    By bheng in forum Revit Architecture - General
    Last Post: 2007-07-23, 10:56 PM
