Thread: Keyboard Shortcuts 2010
    2007-06
    Melbourne, Australia
    602
    Default Keyboard Shortcuts 2010
    Hi All,
    Having sorted out most of the stability problems with 2010, I have just started updating the Keyboard Shortcuts to put in the stuff I use all the time and have come across a hitch.
    Previously in 2009 if I wanted to load a family (or more likely a number of families at the same time), I would simply type "LF" which is my shortcut to the command & bingo I would be straight into the library and would happily collect what I wanted and return to contiune working.
    Unless I am much mistaken, I can no longer do this in 2010 as there is no longer a comparable command in the keyboardshortcuts.txt file. I can create a shortcut to load a component & then click load family.
    Likewise, there are other command which no longer seem to be available for a shortcut (Close File for example)
    Is this correct??? And more importantly, is there a way around it?
    I hope I am wrong, but I fear that I am not. It would be absurd to remove a shortcut and replace it with a shortcut and a click.
    Cheers,
    Ian
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,731
    Default Re: Keyboard Shortcuts 2010
    It's there, I have it assigned under the Insert Tab grouping.
    "LF" ribbon:"Insert-Load from Library-Load Family"
    Close is also there under the AppMenu grouping
    ; "" AppMenu:" Close "
    2007-06
    602
    Wink Re: Keyboard Shortcuts 2010
    Thanks Chad,
    It's late on Friday & when I read something over and over again I tend to miss whatever it is I am looking for every time.
    Thanks again
    Ian
  1. Autocad 2010 keyboard shortcuts list
    By kathey1 in forum CAD Management - General
    Last Post: 2010-10-14, 11:00 PM
  2. 2010 - Keyboard Shortcuts
    By saeborne in forum Revit Architecture - General
    Last Post: 2009-05-21, 06:16 PM
  3. Additional Keyboard Shortcuts - 2010
    By need4mospd in forum Revit Architecture - General
    Last Post: 2009-05-13, 04:41 PM
  4. Revit 2010 - Keyboard Shortcuts Migration
    By Batman in forum Revit Architecture - General
    Last Post: 2009-04-28, 07:53 PM
