Thread: Link Point Elevations to Surfaces to act like Spot Elevation Labels
    Wish List Administration
    2007-08
    434
    Default Link Point Elevations to Surfaces to act like Spot Elevation Labels
    Summary: Add the ability to link a points elevation to a surface. This will allow the point to be used as a spot elevation label and would ensure the point elevation is always current with he surface.
    Description: I would like point objects to be able to be linked to a specified surface dynamically, much like a spot elevation. This would provide added value as then points can actively be used as spot elevations and are not lost if the surface is deleted / broken.
    How Used: I would use points as spot elevations.
    Feature Affinity: Points
    Submitted By: kurt baldwin on January 21, 2009
    2014-06
    Default Re: Link Point Elevations to Surfaces to act like Spot Elevation Labels
    Definitely agree with this post.......why can't we dynamically link/associate a point group, i.e. Finished Grade Points to be dynamically linked to a surface i.e. Finished Grade - I'm constantly updating my surface and then I need to always take another step to move the points upto that surface. I know Sincpac-C3D-$$$ can do it, but I'm already coughing up the money for the C3D license as it is?? It would be nice to get something that I can use in the next annual update
    2012-01
    I may be overlooking something the OP is trying to accomplish, but if the C3D point takes the elevation from the surface, then why not use a surface label to show the spot elevation instead of a point?
    2015-10
    Central New Jersey
    439
    I agree with jwalton, provided the only purpose is to produce an elevation label. Surface labels update when the surface updates.
  1. 2016: REVIT 2016: Spot elevation/Invert elevation for fabrication part.
    By swapr78 in forum Revit MEP - General
    Last Post: 2015-07-03, 11:52 AM
  2. 2014: Can't Tag Spot Elevations on Surfaces in some views
    By Limbatus in forum Revit Architecture - General
    Last Post: 2014-11-12, 10:05 PM
  3. 2014: elevation target arrow head for spot elevation
    By jledgewood in forum Revit Architecture - General
    Last Post: 2014-04-07, 07:58 AM
  4. 2014: Spot Elevation with Boxed elevation text
    By kchenault in forum Revit MEP - General
    Last Post: 2014-02-27, 05:20 PM
