Thread: Anyone running ACA 2010 on an older machine?
    2008-09
    11
    Default Anyone running ACA 2010 on an older machine?
    I haven't installed it yet - 2009 is actually running quite smoothly - but I have an older machine: Windows XP SP2 - 2.4Ghz - P4 - 3G ram, Nvidia GeForce FX 5500 graphics card. Not sure that I actually meet the minimum specs for 2010. It seemed like I wouldn't meet the min specs for 2009 - but it actually runs very well on my machine.
    Just curious if anyone has installed 2010 on an older machine and if there is anything I might know ahead of time....
    Thanks in advance.
    2007-08
    76
    Default Re: Anyone running ACA 2010 on an older machine?
    it should be ok, i dont have as much computing power as you do.
    2.4 GHz
    1 GB of ram
    2008-09
    11
    Thanks for the reply dbrownson.
    Yeah the machine I have doesn't seem to "technically" meet the specs - but I don't really use intensive 3D or any of the upper level features of ACA so I've actually been running 2009 very fast.
    I'll install 2010 and post back with any issues.
    2007-08
    76
    Thumbs up Re: Anyone running ACA 2010 on an older machine?
    You will be fine, three gigs of ram blows me out of the water.
    2002-09
    Madison, WI
    5,687
    Quote Originally Posted by dbrownson View Post
    FYI
    If you put 3 gigs in and you're running XP don't forget about the 3 gig switch. Unless you set up the switch, XP won't see the 3 gigs you have.
  1. Running Trueview 2013 on older computers.
    By d.m.polsky in forum DWG TrueView - General
    Last Post: 2012-05-03, 04:08 PM
  2. REVIT 2010 32 BIT on 64 BIT machine
    By brentt in forum Revit - Hardware & Operating Systems
    Last Post: 2010-03-12, 10:04 PM
  3. Running AutoCAD MEP in Virtual Machine
    By kmorin in forum Software
    Last Post: 2010-02-26, 12:55 AM
  4. Will my machine run 2010?
    By gusaluphagus in forum AutoCAD General
    Last Post: 2009-04-17, 08:09 PM
  5. Windows XP - problem running Autocad 2008 on a XP virtual machine
    By radin.hairul.anwar in forum Operating Systems
    Last Post: 2008-05-14, 09:25 AM
