Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Renaming Attribute Tags?
    2008-09
    9
    Default Renaming Attribute Tags?
    Does anyone know of a way, or have a routine, that will edit the tag name (not the value) of an attribute in an existing block? I'm aware of BATTMAN's capability here but I have a HUGE number of drawings that require some tag renaming and I'm hoping to create a script to run overnight.
    Randy
    I could stop if I wanted to msretenovic's Avatar
    2002-02
    Galloway, Oh
    305
    Lightbulb Re: Renaming Attribute Tags?
    Quote Originally Posted by rkingery View Post
    Randy
    Randy,
    Give this a try:
    (defun MKSxAttTagSet
              (obj   ;;variable - object to use
               att   ;;variable - attribute to set
               str   ;;variable - new tag name
               atts  ;;variable - list of attributes
               bool  ;;variable - returns t if set, returns nil if not
               index ;;variable - index/counter
      (setq    atts  (vlax-safeArray->list (variant-value (vla-getAttributes obj)))
        index 0
      (repeat (length atts)
        (if    (= (vla-get-tagString (nth index atts)) att)
          (progn
        (vla-put-tagString (nth index atts) str)
        (vla-update (nth index atts))
        (setq bool t)
        (setq index (1+ index))
      bool
    You would call it like this:
    (MKSxAttTagSet objBlk TagOld TagNew)
    This routine will update ALL attribute tags with the old name (TagOld). If nothing it updated, nil is returned; otherwise t is returned.
    Michael K. Sretenović
    Most folks are about as happy as they make up their minds to be.
    -Abraham Lincoln (1809-1865)
    -16th president of The United States of America (1861 - 1865)
    2015-11
    Jo'burg SA
    4,512
    Default Re: Renaming Attribute Tags?
    Similar to msretenovic's code. Although you simply give it the block's name, the old tag name & the new tag name. Renames these for both the block's definition as well as any block references (even when nested inside other blocks).
    ;;; Rename attributes
    (defun RenAttrib ($blk $old $new / blocks bo eo ao)
      ;; Get blocks collection in current drawing
      (setq blocks (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))))
      ;; Step through all blocks
      (vlax-for bo blocks
        ;; Step through all entities inside block
        (vlax-for eo bo
          (cond
            ;; If attdef & in target block & old tag
            ((and (= (vla-get-ObjectName eo) "AcDbAttributeDefinition")
                  (= (strcase (vla-get-Name bo)) (strcase $blk))
                  (= (vla-get-TagString eo) $old)
             ) ;_ end of and
             (vla-put-TagString eo $new) ;Change to new name
            ;; If block reference & target block
            ((and (= (vla-get-ObjectName eo) "AcDbBlockReference")
                  (= (strcase (vla-get-EffectiveName eo)) (strcase $blk))
             ) ;_ end of and
             ;; Step through all attributes
             (foreach ao (vlax-safearray->list (vlax-variant-value (vla-GetAttributes eo)))
               ;; Check if target attrib
               (if (= (strcase (vla-get-TagString ao)) (strcase $old))
                 (vla-put-TagString ao $new) ;Change to new name
               ) ;_ end of if
             ) ;_ end of foreach
          ) ;_ end of cond
        ) ;_ end of vlax-for
    ) ;_ end of defun
    Example usage, at the command line (or in script). Assume block's name is TESTBLK, old Attrib Tag name is OLDTAG & new tagname is NEWTAG:
    (RenAttrib "TESTBLK" "OLDTAG" "NEWTAG")
    2008-09
    9
    Thanks guys! Worked beautifully!
    I could stop if I wanted to chillme1's Avatar
    2006-05
    TN
    287
    Question Re: Renaming Attribute Tags?
    Newbie here: How could the be modified to rename several attribute tags and replace each with a corresponding new tag?
    (Clint)on Hill
    CAD Systems Operation and Management
    Autodesk and CADWorx Design Software
    www.innophos.com
    "Check out the free e-mail discussion group at: www.waun.org"
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by Clinton.Hill View Post
    Renaming the insert's attributes is quite simple. A normal entmod does this without hassles, or as per the previous code. The tricky bit is to figure out which old name needs to be changed to which new name - you either need a prepared list of OldName->NewName or you need to ask the user all the time . Then a simple AttSync would suffice to modify any properties to the new attribute's definition.
    2006-05
    TN
    287
    Smile Re: Renaming Attribute Tags?
    Do you have an example or tips on constructing a list of old and new attribute tag names that will be used by LISP:
    File content formatting
    File extension, etc.
    Other special considerations...
    Are there any links to instruction on or samples on how to use a list using either AUTOLISP or VISUAL LISP that you could forward?
    (Clint)on Hill
    www.innophos.com
    2015-11
    Jo'burg SA
    4,512
    All you need is a list which you'll need to create for yourself. Something like this:
    (setq attrename-list
      '(("BlockName1" ("OldAttName1.1" "NewAttName1.1") ("OldAttName1.2" "NewAttName1.2"))
       ("BlockName2" ("OldAttName2.1" "NewAttName2.1") ("OldAttName2.2" "NewAttName2.2"))
    Then you can step through that list and call something like my routine in post #3 thus:
    (foreach block attrename-list
      (foreach attrename-pair (cdr block)
        (RenAttrib (car block) (car attrename-pair) (cadr attrename-pair))
      (command "._ATTSYNC" "_Name" (car block))
    Note though: this is untested, so you might have to tweak it a bit . And I think it's working only with case sensitivity - to get around that the RenAttrib defun needs some changes. Also this isn't the most efficient route as it's looping through the list and for each attribute rename pair goes through all the entities inside the DWG (there's probably a much faster method).
    I found this on the web after receiving no help at the autodesk forum. I just tried loading the "RenAttrib" lisp. It loaded okay but when I put the text in the command line I get the error shown below.
    ILMST is the block name
    04-16-90 is the existing attribute tag name
    START_DATE is the new tag name I want to give it
    Command: (RenAttrib "ILMST" "04-16-90" "START_DATE")
    ; error: no function definition: VLAX-GET-ACAD-OBJECT
    I'm not a programmer so I don't know how to correct this. Can anyone help?
    Thanks
    Mike
    PS: If this can be done with a script that would be much easier.
    Last edited by bustr0giantcatfish974410; 2012-03-27 at 08:46 PM. Reason: Post Script
    2015-11
    Jo'burg SA
    4,512
    It's using the Visual Lisp extensions - which aren't loaded by default. Just add the following line of code somewhere into that lisp (or any other lisp loaded automatically) - it only need be run once per drawing (so most of us would already have such somewhere, that's why these lisps don't include it):
    (vl-load-com)
  1. 2013: Xrefs and Attribute tags
    By gjh in forum AutoCAD LT - General
    Last Post: 2014-05-10, 09:49 PM
  2. Attribute Tags
    By RobertAitken in forum VBA/COM Interop
    Last Post: 2010-06-11, 11:01 AM
  3. Re-use attribute tags
    By nancy.beulens in forum AutoCAD General
    Last Post: 2009-12-29, 03:23 PM
  4. Renaming Tags
    By kenneth_white in forum AutoLISP
    Last Post: 2008-02-08, 10:52 PM
  5. Renaming Fields in Room Name Tags
    By Gardinine in forum Revit Architecture - General
    Last Post: 2003-09-04, 01:23 AM
