Thread: Tagging levels
    2007-03
    27
    0 Did you find this post helpful? Yes
    Default Tagging levels
    hi,
    I am using revit 09, i need to tag my floor levels (both Structural slab lvl and finished floor lvl) and i need to tag my false ceiling lvl in floor plan. I tried with spot elevation for floor slab lvl i am able to get FFl but i don’t know how to add prefix (FFL) to it and i also don’t know how to bring SSL (Structural slab Lvl as i said before!! And i need box around my tags (please refer attachment). For false ceiling i am drawing a line by underlying false ceiling plan and locking with my ceiling but don’t know how to bring the level for false ceiling in floor plan. For Time being i am using everything as text............please help me to solve this issue.
    Pittsburgh, PA USA
    1,906
    Default Re: Tagging levels
    You are not going to get them into one tag that provides both slab levels. You may be able to create a custom spot elevation that provides a box, I have not tried that before. In order to get both levels, you'd have to model both floors/levels. I do not believe you can add shared parameters to this tag, that would "calculate" the structural slab from the finished level, or visa-versa.
    2006-10
    Cape Town
    94
    You can do the box by editing the label used, but certainly not get both heights at once.
    I am alos battling to get SSL when the floor is modeled with finish. A formula referencing FFL seems impossible and there is no other way I can find to reference top of structure allthough the floor itself makes the destinction.
  1. Replies: 3
    Last Post: 2015-08-25, 05:23 AM
  2. Auto Tagging
    By Dr._House in forum Revit MEP - General
    Last Post: 2011-08-03, 07:07 PM
  3. Architect's Levels & Structural's Levels
    By sjsl in forum Revit MEP - General
    Last Post: 2009-09-11, 01:22 PM
  4. Tagging in 3D
    By 4hoursstanding in forum Revit Structure - General
    Last Post: 2007-01-12, 04:38 AM
  5. tagging walls
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-12-09, 02:11 AM
