Hi
How can i get a dwg imported on one level to show as an underlay on the level above?
I have set the underlay and view range options but can't get it to show
Thanks
Hi
Thanks
Hi there,
I believe that this is a "view specific" issue. If you have a DWG imported into the project, simply open the Level Above plan and set the Visibility controls to show the imported DWG on that plan view.
Maybe I am missing something; however, I don't remember ever using an imported DWG as an underlay.
Good Luck
Steve Shell
I did. O.k. thanks i deselected it and it worked fine
I just presumed it would have shown on all levels if i didn't check it
Thanks anyway
In this same vein. I imported a drawing in a specific view only. Is there a way to get it to show in other views? Do I have to unload it then reload it?
