Results 1 to 10 of 11
Thread: 2010 Ribbon question
    2005-04
    77
    Default 2010 Ribbon question
    I'm using Civil 3D 2009, type most of my commands use about 5 toolbars and have not been using the ribbon (I'm not so sure I like it yet). I've heard I need to get used to the Ribbon for the new release. Where will I find the object snaps now? 1/3 of the icons don't show up in the panels, Maybe it's there and I haven't found it.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    Default Re: 2010 Ribbon question
    If I remember correctly the osnaps are not in the ribbon. The osnap toolbar is still in the acad.cui.
    Jeff Paulsen
    2005-04
    77
    I was told we won't have a tool bar....only the Ribbon.
    Please Please Please tell me we still have toolbars and essintially nothing looks like it changed (after you minimize the ribbon)
    0,0,0 The Origin
    8,026
    In vanilla acad you can switch to the "classic" workspace and get rid of the ribbon. Does that apply to Civil?
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    621
    Quote Originally Posted by avn View Post
    They aren't there but it wasn't too bad to add in, I just added them to the draw panel,
    2001-05
    Austin, TX USA
    2,201
    Using the ribbon in Civil 3D 2009 is not recommend. The ribbon wasn't finished for C3D and there are issues with using it.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2002-04
    Colorado
    1,901
    Please Please Please tell me we still have toolbars and essentially nothing looks like it changed (after you minimize the ribbon)
    As far as I know all of the AutoCAD toolbars are still there. The Acad.cui is loaded as a partial to Civil so all of those toolbars are available in C3D. However, most of the C3D toolbars are gone. The only ones left are the Transparent Command and Transparent Command Filters toolbars.
    To open a toolbar when none are visible I use the -toolbar command. You can turn on all of the toolbars or turn on one with a short name like "draw". Once you open a toolbar and dock it you can use the right-click to open additional toolbars from any of the loaded CUIs.
    Does anyone know a better way, other than -toolbar, to open a toolbar if none are open?
    Quote Originally Posted by jaberwok View Post
    All of the workspaces in C3D 2009 have the ribbon turned off and have some toolbars on. All of the workspaces that ship with C3D 2010 have the ribbon turned on an have no toolbars active.
    Quote Originally Posted by Richard.Kent View Post
    This is a good approach if you want to add them to the ribbon. This is what I would probably do. But as I mentioned above you can still use the acad toolbars.
    Jeff Paulsen
    2002-04
    Colorado
    1,901
    Quote Originally Posted by Glenndp View Post
    What issues have you heard of? I've been using the Ribbon in 2009 for a year and haven't had any problems. Granted, I don't use it often since the C3D 2009 ribbon only had AutoCAD commands on it but it is on in my workspace.
    Now that I think of it, we did have some issues with the context sensitive ribbons like for mtext editing. We had to change a variable to make it work correctly but I don't recall what it was.
    Jeff Paulsen
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by jpaulsen View Post
    Those were the same issues I was having. The context ribbon for the block editor didn't want to work right, and would have to turn the ribbon off before using the editor. Plus had issues with adding several new tabs and panels. Tried creating panels for all the C3D tools.
    Also in the discussion groups one of the Autodesk guys stated there were issues and didn't recommend using it. Tried to find the post but didn't see it.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    2002-04
    Colorado
    1,901
    I did not try to do any customization so that's why I probably did not see as many issues as you. It is my understanding the the latest updates resolved a lot of the issues with customizing the ribbon.
    Jeff Paulsen
  1. ACA 2010 Ribbon Problem
    By scompton in forum ACA General
    Last Post: 2010-06-11, 09:18 AM
  2. 2010 Ribbon freak out
    By wadeshuey in forum Revit Architecture - General
    Last Post: 2010-04-29, 03:46 PM
  3. 2010 Ribbon Question
    By jsimon.216607 in forum Revit - API
    Last Post: 2010-01-18, 07:12 PM
  4. RAC 2010: Crash with ribbon
    By francopretti in forum Revit Architecture - General
    Last Post: 2009-05-27, 08:19 AM
