DaveP
We created three Panel Types (all the same family, different Types)
There's a Center Panel Type, a Left, and a Right.
In the Family, we added a Reference Plane on either side of the Panel, and dimensioned them so they extend past the Curtain Grid the same distance that the glass is offset from the Curtain Wall.
The Center panel works the same as the OOTB Curtain Wall Panel
The Left panel Type extends "Offset" distance to the left, and the Right panel Type extends to the right.
Since the extension distance is the same as the Offset, the two panels overlap each other by the correct amount regardless of the construction of the Wall. And, as Greg says, you can easily select all of the panels in a vertical column, so it's fairly easy to just change the panels on both ends.
(Hope that all made sense)
