Results 1 to 9 of 9
Thread: polyline vs 2d polyline
    2004-06
    Slidell, Louisiana
    612
    Default polyline vs 2d polyline
    I have searched for an explanation but can't find one. Can someone explain the difference between a polyline and a 2d polyline and why does Autocad have both.
    Robert
    2005-06
    in the upper right corner
    3,051
    Default Re: polyline vs 2d polyline
    Quote Originally Posted by rmk View Post
    If I'm not mistaken, a polyline is a 2d polyline, (I don't know of a 2d pline command).
    There is a 3D polyline though, command: "3dpoly" where you can set vertices at different elevations as well as x and y coordinates.
    So to recap, "pline" = 2d polyline, versus "3dpoly" = 3d polyline.
    thats my take on it.
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    2006-12
    Big "D"
    3,711
    I found this searching google:
    2D Polylines are the old style polylines. They store their vertex
    information inefficiently compared to the lightweight polyline, or the
    "normal" polyline to which you are used.
    and this
    a 2d polyline wil take up more memory than a regular polyline, as the vertex information is stored differently. the current 2d polyline system is how all 2d polylines used to be stored, and cad moved towards the newer way, "regular polylines" to cut down on memory use and regen time
    Why is it called common sense when it is so rare?
    RevitForum.org
    2005-07
    2,356
    Quote Originally Posted by dzatto View Post
    That's correct, 2d polylines are legacy objects from Acad R14 and earlier.
    2004-06
    Slidell, Louisiana
    612
    Thanks for trying to explain it, but it is still as clear as mud to me. is there a way to convert 2d plines to "regular" plines, or am i stuck with them. i am trying to do some data extraction and some of the lines or regular and some are 2d. any suggestions.
    Robert
    2005-07
    2,356
    Simply using the polyline edit (pedit) command on a 2D polyline converts it to a standard pline.
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by H'Angus View Post
    Or you could use the CONVERTPOLY command. This lets you do multiple plines at once. You want to convert them to "light" plines.
    RevitForum.org
    0,0,0 The Origin
    8,569
    Terminology only -
    the new-style polylines are often called "lightweight polylines" because they require less data storage.
    as a result, older polylines are occasionally referred to as being "heavyweight".
    I doubt that any of this will affect your data extraction though.
    John B
    100 Club sandeep_koodal's Avatar
    2007-10
    God's Own Country
    183
  1. 2013: z value at intersection points in 3d polyline and polyline
    By jaychandran in forum AutoCAD Civil 3D - General
    Last Post: 2013-10-30, 05:20 PM
  2. Replies: 14
    Last Post: 2007-09-10, 05:01 PM
