david_peterson
Are you talking about the elevation "Generation" Tag or the elevation Marker (ie T/ steel = 100'-0") kind of thing.
The Marker I thought were model based, so depending on what you attached them to, it should give you the correct elevation. Personally if your talking about detail sheets, I'd still go with a manual version and fill it to say see plan or see elevation or see section.
While some would say "Hey why not put the actual elevation on the detail, it's linked to the model, you know it's correct" Here's my response "When it changes after it went out to bid, while the drawings are coordinated, now you have to issue a sketch or a revised sheet where ever that elevation shows up."
I just got burned on this on my current project (I'm stuck with Revit right now) and I made the mistake of labeling everything cause I know it would be coordinated. Well, now I'm screwed because the archies changed their mind and I have to re-issue a bunch of sheets.
2 more cents for ya
