Thread: Table Styles in 2010
    2008-02
    4
    Default Table Styles in 2010
    Are table styles created in AutoCAD 2006 compatible in 2010?
    When I paste-special cells from Excel into 2010, they do not format to the table styles that have always used with AutoCAD 2006.
    I appreciated any help.
    All AUGI, all the time Capt. Computer Crasher's Avatar
    2006-12
    South of North & East of West
    786
    Default Re: Table Styles in 2010
    Quote Originally Posted by we3hobbs View Post
    I don't have access to AutoCAD2010 but I going to go out on a climb and say no. The reason is from AutoCAD2006 (saves as a 2004 format) to AutoCAD2010 (saves as a 2010 format) there have been two file format changes plus mega improvement in how tables operate and function. In fact, if you use the table command there should be a option to data-link the Excel file without having to use paste special. Try it that way and see if the formatting is better, other than that I think you may have to create new table styles.
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    AutoCAD 2008 introduced DataLinks which gives you a link between the AutoCAD table and the Excel data.
    You may want to try creating the DataLink before placing the table. There are options in there for formatting, but you cannot select a specific table style. The formatting will usually be based on the formatting in Excel.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2006-12
    786
    Quote Originally Posted by RobertB View Post
    yes you can select a specific style.The use Ecxel formatting must be unchecked.
    2001-08
    Dallas TX USA
    5,825
    Red face Re: Table Styles in 2010
    Quote Originally Posted by Capt. Computer Crasher View Post
    Thanks for correcting that. I did not have the chance to directly use AutoCAD to test it, and relied on the docs, which didn't cover that.
    R. Robert Bell
    S P A R L I N G
    2006-12
    786
    in 2008, it is a collaspable dialog box, if the arrow by the ok is not clicked then all those settings about using the excel formatting are hidden. Why AutoDesk did that I do not know. Most people can't find the setting.
  1. table styles with notes
    By kgomez in forum AMEP General
    Last Post: 2008-07-17, 06:51 PM
  2. Where's the table/table styles data
    By jorozco in forum AutoCAD Tables
    Last Post: 2006-11-03, 05:19 AM
  3. Schedule Table Styles
    By BCrouse in forum ACA General
    Last Post: 2005-09-28, 05:06 PM
  4. Saving table styles
    By Baghera in forum AutoCAD General
    Last Post: 2005-05-04, 02:32 PM
