Results 1 to 10 of 17
Thread: Where is "cut plan profile"
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,268
    Default Where is "cut plan profile"
    Okay, I'm giving this 2010 a chance and my god is it a waste of time. I am looking for the "cut plan profile" command to edit an extruded roof and it is nowhere to be found. So I check in "Where is my command" and it is not there.
    The "where is my command " feature is just plain stupid. How can you possibly leave "copy" out of the list? If you are going to alter the entire UI you should at least make a half baked attempt to keep your users from wasting hours and hours chasing down where you have hidden the commands. Just imagine the wasted manhours that are being generated because Autodesk can't be bothered to spend the time to prepare decent help files.
    2003-11
    441
    Default Re: Where is "cut plan profile"
    Are you referring to Edit Cut Profile? It's found on the Modify tab and shortened to Cut Profile.
    2003-04
    Irvine, CA
    6,770
    Select the Roof, Modify Roofs Ribbon tab > Modify Roof panel > Vertical Opening
    2003-12
    Victoria, BC
    1,268
    I am not looking for "Vertical Opening " I am looking for the tool that used to pop up on the Options bar when you selected an extruded roof. The tool is called "Cut Plan Profile".
    2003-04
    Irvine, CA
    6,770
    That is the tool now...it does the "same" thing. You sketch the same sort of boundary just not creating a "hole".
    2003-12
    Victoria, BC
    1,268
    If Autodesk is going to change the location of the command as well as the name, perhaps they might think it prudent to mention it somewhere in their hopelessly lame documentation.
    2003-04
    Irvine, CA
    6,770
    Where's your sense of "adventure"? It's not software it's an adventure! Ever notice when someone is in pain it sorta looks like a smile...if you look quick.
    2003-12
    Victoria, BC
    1,268
    Oh like one of those old text based adventure games...You are in a dark cold room deep underground.. it is late at night... You suddenly need to cut a shape in an extruded roof.....
    2005-07
    3,220
    I'm not so sure I agree with the semantics of the naming of that command. I think I commented about it on the Revit Factory blog. To me a vertical opening is an opening on a vertical plane. At least, that's what I think of if the text isn't accompanied by that icon!
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,729
    I agree with David on this one. The naming isn't all that great.
    Take the Wall Opening tool. This being the opposite of the Vertical Opening, it could logically be called Horizontal Opening. But this creates imagery of sketching on the horizontal. The Vertical Opening naming is no different.
    One thing I've never understood is why Roof By Extrusion has a Vertical Opening modify tool, but to do the same with a Roof By Footprint it is another tool somewhere else in the program.
  1. "detail view" vs "floor plan" in callouts
    By shane.249457 in forum Revit Architecture - General
    Last Post: 2011-03-08, 08:29 PM
  2. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum Español - AutoCAD Civil 3D
    Last Post: 2009-02-01, 03:21 AM
  3. Curtain wall "Profile line" moves
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2006-08-22, 02:27 PM
  4. Replies: 1
    Last Post: 2006-06-13, 06:36 PM
  5. Editing via "Profile Grid View" not working any longer
    By b.mossman in forum AutoCAD Civil 3D - General
    Last Post: 2005-08-15, 04:02 PM
