Thread: DB to create staggered rows
    I could stop if I wanted to nextvkin's Avatar
    2007-07
    315
    Default DB to create staggered rows
    I've made a db to create a tile pattern which has every other row staggered (attached), however, this only allows me to have an even number of rows. Is there another way to make it so that it can have an odd number of rows as well? Thanks.
    Kay.
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: DB to create staggered rows
    Quote Originally Posted by nextvkin View Post
    Kay.
    have you thought of using an associated hatch where the coursing parameter is set to "increment" to match the pattern distance? the horizontal stretch could be anything....
    S&D DB Sharing Forum
    2001-12
    Rochester, MN
    2,561
    ok, i will find myself guilty for not knowing what i'm talking about. i assumed you were talking about a "running bond" tile pattern, not an 'accent' tile pattern.
    only thing i can think of that would work for you would be to use a lookup for the rows (would have to use a linear parameter for each tile independantly)
    this way, all you'd have would be the horizontal grip.
    2007-07
    315
    Chris, thanks for the reply, but I have a bit of trouble understanding what you mean However I've come up with an idea which works for me - I've attached it in case anyone's interested, or can improve on it,
  1. 1/3 Staggered Running Bond
    By chazkelly in forum AutoCAD General
    Last Post: 2012-08-08, 07:31 PM
  2. Staggered wall clean-ups
    By ws in forum Revit Architecture - Tips & Tricks
    Last Post: 2008-08-15, 04:05 PM
  3. Replies: 7
    Last Post: 2006-10-21, 03:02 PM
  4. Staggered Section Lines
    By Davied2 in forum Revit Architecture - General
    Last Post: 2004-09-19, 09:52 AM
  5. Staggered Section
    By gmak in forum Revit Architecture - General
    Last Post: 2004-06-09, 12:25 AM
