Thread: Beam Annotation Tool Bug
    2002-09
    Madison, WI
    5,503
    Default Beam Annotation Tool Bug
    I don't know that I should truly call this one a bug, but it's not the way the tool should work.
    If you need to add some framing to a plan after your sheets are already set up and looking good (ie you've gone and hidden all he stuff you don't want to see on that sheet) and you use the beam annotation tool you get an error message that says "Some elements have tags hidden in this view. These elements will be re-tagged and hidden elements will be revealed."
    First off this makes no sense to me. I just placed these beams, I deleted the tags they came in with. I just want to tag these new beams. In order to use the tool, I now have to waste a bunch of time to go back though my drawings and hide all the stuff I've already done. I thought this program was supposed to make thing faster and less repetitive. I guess I was wrong. This tool works great for the most part, but this aspect of it just sucks.
    Am I missing something with this tool, or is this just another one of those "Opps, I guess we'll pass the issue to the development team which might get to it about 2015"
    Or am I missing one of those fine check boxes somewhere along the way.
    Thanks in advance.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    2006-09
    442
    Default Re: Beam Annotation Tool Bug
    I am not quite sure if this is what you are refering, but thought I would mention it. When you click on the Beam tag tool, it will default to tag all beams in the view. What seems to work better is to click on a beam, then click on the beam tag tool. Then it will default to selected beams, and only tag your selection. Also watch for replace existing tags setting.
    2002-09
    Madison, WI
    5,503
    I was only selecting the new beams I added. Not the "tag all" option.
    I selected the individual beam, unchecked the "replaced existing tags" still got the same error.
    Dave Peterson
    BIM Coordinator
    2008-06
    Denver, CO
    179
    Is there a way to get this Beam Annotation Tool to save it's defaults? I know it's not that much time to click each box and select the tags each time (as well as setting the offset) However, I want to set this in our template so people don't screw it up.
    Ryan Taube LEED AP
    ___________________
    100 Club BecFra's Avatar
    2007-03
    Rock Island, IL
    114
    Yep, just open up your template and set the beam annotation tools how you like. and save. The next time you start a project with that template they will be there!
    Becca Frangipane
    Structural Technician
    KJWW Engineering Consultants
    2002-09
    Madison, WI
    5,503
    This is still an issue in my mind.
    I don't want to re-tag all the items. I just need to tag a few new beams.
    I've used the hide object in view for misc annotation that's outside or on the edge of the view. ie I don't want them to show up in that dependent view.
    But if I use the Beam Annotation tool, it un-hides anything that I've hidden. So it causes re-work.
    The tool shouldn't work this way. If I only want it to tag one beam, I don't want it to effect the other work in the view.
    Dave Peterson
    BIM Coordinator
  1. The beam system tool should allow users to specify the location of the first beam.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-06-08, 03:32 PM
  2. Default Beam Annotation Placement
    By rsotak in forum Revit Structure - General
    Last Post: 2011-12-15, 08:46 PM
  3. using the the 'beam system' tool
    By JRBOURNE in forum Revit Architecture - General
    Last Post: 2011-03-31, 02:00 PM
  4. Beam Coping Tool ?
    By mbalsom in forum Revit Architecture - General
    Last Post: 2008-04-10, 02:42 PM
  5. Beam Tool
    By dmb.100468 in forum Revit MEP - Wish List
    Last Post: 2008-01-05, 12:42 AM
