Thread: AutoCAD 2010 Tool Palettes
    2007-02
    61
    Default AutoCAD 2010 Tool Palettes
    Hi All:
    I've just moved on to AutoCAD 2010 from 2008 and my tool palettes .xtp's have been changed. The file names now have additional characters added to the original file name eg: Components_415D93B4-3A0A-4300-AD7C-86336E658548.atc was once Components.xtp. When I try to customize the palettes and import my palette AutoCAD looks for a .xtp file so I cannot import the now changed file. I then tried changing it back to its original file name with the .xtp ending and then try to import but AutoCAD replies "The file you have selected is not a valid palette definition file."
    Further to this I keep these custom palettes on the server, so when I loaded 2010 it made these changes there over the network, not just on my own desktop.
    Any ideas why this is happening and what I should to to get my palettes to import?
    Thanks.
    I could stop if I wanted to artisteroi's Avatar
    2007-02
    Tampa, FL
    271
    Default Re: AutoCAD 2010 Tool Palettes
    atc files are a sorta delimited text file with instructions for acad on pathways for a pallette. They must have changed how the basic pallette system works. I would suggest rebuilding your pallettes in 2010 and then following the instructions for sharing them with other users. It will be easier to rebuild it than to try to make it work again from an older version. Hope you didn't have to many of them.
    Member miles9x's Avatar
    2006-01
    North Dakota
    17
    I was able to create a new blank toolpalette.atc file, open it with notepad and paste the contents of a 2009 palette into it and it worked. Also, i created a new toolpalette.atc file by renaming a blank text document, paste the header from another toolpalette file into it, and it appears to work without all the extra characters in the name of the palette. I haven't added any elements to this palette yet but it shows up in the program just fine.
    here is the contents of my blank tool palette User.atc
    <Palette FileRevision="18.0.0" Revision="18.0.1" option="0"><ItemID idValue="{00000000-FA09-46C8-A29D-D67FD2F6DD54}"/><Properties><ItemName>User</ItemName><Images option="0"/><Time createdUniversalDateTime="2009-06-29T19:53:59" modifiedUniversalDateTime="2009-06-29T19:53:59"/></Properties><CustomData><Translation status="1"/></CustomData><Source/><Tools/></Palette>
  1. CP223-1: Trick Up Your Tool Palettes: How to Make Your Tool Palettes Do Even More!
    Last Post: 2015-08-07, 05:17 PM
  2. ACA 2010 Tool Palettes error
    By mwhiteside.223248 in forum ACA General
    Last Post: 2010-03-19, 11:17 PM
  3. Replies: 1
    Last Post: 2006-05-14, 06:00 PM
  4. Replies: 2
    Last Post: 2006-05-12, 01:40 PM
  5. Tool Palettes Not Loading with AutoCAD
    By dgalloway in forum AutoCAD Customization
    Last Post: 2005-08-09, 09:42 PM
