Originally Posted by
mcaddc
Hi Clog Boy,
Thanks for your asistance. To answer some of your questions, yes, I did want the first and second also at 450 at all times, and the last at less than 450. I also did put a stud at the end and aligned with that.
I played around with the formula and realized from your comments that the calculation for the array was an integer value. So when rounding comes into effect from the resultant decimal places by dividing the length by a fixed number, I modified the equation to help tip the integer to the next whole number. eg, (Length / 450 mm) + 0.3
This seems to have fixed the occasional missing stud.
btw, the stud is also a nested family.
So that's great for now! Next I need to learn how to error control the family so that it doesn't spit the dummy if I draw a short segment!
Thanks Again for all your help!
