Thread: Embedded images
    2006-04
    85
    Default Embedded images
    Folks,
    there are 2 embedded images in the attached file but I can't see them using TrueView 2010. If I unembed them, they become visible. Do I need to change settings in AutoCad 2008 or TrueView or is there a more deep-seated problem?
    Houston
    7,519
    Default Re: Embedded images
    They show up as proxy objects here, which means you need the Raster Design Object Enabler. Unfortunately, I don't see TrueView listed here: http://www.autodesk.com/oe
    2009-06
    you can close the proxy
  1. Embedded Raster Images
    By dbeavers in forum DWG TrueView - Wish List
    Last Post: 2009-07-27, 11:11 AM
  2. Embedded Objects
    By ty_demo15 in forum AutoCAD General
    Last Post: 2008-10-14, 02:00 PM
  3. Embedded IF/AND ?
    By The Sweg in forum Revit Architecture - General
    Last Post: 2008-08-07, 08:26 PM
  4. Plotting DWF files with embedded tiff images
    By hagibis in forum AutoCAD Plotting
    Last Post: 2006-07-15, 06:50 PM
  5. Embedded wall?
    By aliya14 in forum Revit Architecture - General
    Last Post: 2005-01-11, 02:02 PM
