Results 1 to 10 of 13
Thread: express tools icons are missing
    2004-08
    137
    Angry express tools icons are missing
    not only are the icons missing, express tools come back with a "TextMask command unknown". I used appload to see if I could load the app. Acetmin.MNL is there but unselected. In the window to pick app to load Acetmin is not there. When I use explore and head toward the system folder I see it. The odd thing about this is that in the Loaded Application window, where Acetmin.MNL is not selected, its path is in the program files>support. I have been at this since yesterday. I have no clue!
    0,0,0 The Origin
    8,026
    Default Re: express tools icons are missing
    What version of acad?
    What icons where?
    Do you see the Express Tools menu tab or Ribbon panel?
    Have you tried "Expressmenu"?
    Do you mean Acetmin or is it Acetmain?
    In Appload, Acetmain should be visible but greyed-out = unselectable.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2004-08
    137
    my bad, I am using ACA-08 a student verison. The icons are icons that r seen in the drop down tab of ET. Yes I see the ET menu tab. I did do expressmenu but things didnt change. Yes I met Acetmain. I thought that is the app I need since that is what is greyed out in the appload window.
    0,0,0 The Origin
    8,026
    Okay, you have a menu tab header "Express" and you see the text menu items but not icons? Do the functions that don't have icons (everything under "Layout tools" for example) work?
    From Tools\Options is the correct path to the Express folder show in "Support File Search Path"?
    The Acetmain files should be in drive:\Documents and Settings\username\Application Data\Autodesk\AutoCAD 2008\version number\enu\Support.
    John B
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    Express Tools is not installed by default. Are you sure that Express Tools has really been installed? The Express Tools CUI file is installed even when Express Tools has not been installed so that is not a reliable indicator.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2004-08
    137
    I saw the Expess file menu when I went to set the path as you wrote. Hit apply-closed- went back to check if CAD did its job and the file name was now the Support File Search Path. But no cigar, I still have the "unknown command". My icons have ? marks and nothing in the ET tab works, whether ? marks or not.I am wondering if my upgrade to xp sp3 has anything to do with this? I had to reformat my pc because of a virsus and had to install everything. I also had to upgrade to the sp3. I have done all that I know.
    2004-08
    137
    Unhappy Re: express tools icons are missing
    ok, then, I thought that I had to just go into menuload and load the acetmain and I would have tools. If that is not the case what is the procedure?
    2001-08
    Dallas TX USA
    5,825
    Arrow Re: express tools icons are missing
    Quote Originally Posted by sherflor View Post
    Go to Add/Remove Programs in Control Panel and modify your current install to include Express Tools.
    R. Robert Bell
    S P A R L I N G
    0,0,0 The Origin
    8,026
    Quote Originally Posted by RobertB View Post
    Wasn't A2008 the one (vanilla) version in which ETs were installed by default?
    It sounds like the text items are there but not the icons - indicating a lost dll file?
    John B
    2004-08
    137
    Wink Re: express tools icons are missing
    RobertB and Jaberwok, you guys are Sweet! My first clue was add/remove, there was not a modify to modity. But, my second clue was that, yes other times that I had to reinstall ET was there and I had to just do a menuload. So I went ahead and and click on Add/Remove Features. And and the Select features to install window popped up, I scrolled down and ET was deselected. I selected and went through the process of install. I have my ET menu working not only that I have the help menu load too. The help menu would never come up well now I know why. I use the help in ET for aliases; I even have icons. The only icons I dont have is when I customize and select either Blocks or Text as tool bars, I still have those ? marks. But the main issue is solved. Wow what a learning expeince.
  1. Lost Default Icons for Express Tools with Customized .cui
    By rbdome in forum AutoCAD CUI Menus
    Last Post: 2010-10-14, 12:25 AM
  2. ADT 2006 - Express Tools icons showing as "?"
    By .chad in forum ACA General
    Last Post: 2007-03-19, 12:45 PM
  3. Express Tools missing from ADT 2006
    By jcapp in forum ACA General
    Last Post: 2006-09-07, 12:45 PM
  4. AutoCAD 2007 Express Tools menu missing
    By ed.wiper in forum AutoCAD General
    Last Post: 2006-06-15, 02:34 PM
  5. Missing Express Tools in AutoCAD 2004
    By bnia in forum AutoCAD General
    Last Post: 2004-07-06, 11:26 AM
