Results 1 to 9 of 9
Thread: Sloped Pad, Sloped Trench...
    I could stop if I wanted to barrie.sharp's Avatar
    2009-01
    UK, South East England
    466
    Default Sloped Pad, Sloped Trench...
    I am designing a wheelchair ramp which climbs a steep gradient.
    The ramp will cut a sloping trench with retaining walls either side.
    I have created the Topo surface and the ramp. I need to cut the trench now... How!?
    Pad option seems to cut a level slab which creates a wedge void.
    Any ideas?
    `Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for'
    Socrates
    2009-02
    Houston
    686
    Default Re: Sloped Pad, Sloped Trench...
    Not sure if this would be the best way to go about it, but maybe you could add points to the toposurface to get the trench.
    2006-03
    London, UK
    810
    Quote Originally Posted by barrie.sharp View Post
    Any ideas?
    I've been wrestling with a similar problem today, and as far as I can tell there's no way to do it without Splitting the topo and removing the part where your trench goes. This prevents the topo Fill from drawing underneath the bottom of the trench, but it does avoid any lines in the 'wedge' area.
    It would be great if Pads had all the controls that Floors did.
    Or if Floors had a 'Cuts Topography' checkbox.
    Pittsburgh, PA USA
    1,906
    Create the pad, and while in sketch mode, You can then add a Slope Arrow to the pad, and define your top and bottom of slope. Then it should cut a sloping trench
    2006-03
    London, UK
    810
    >_< I've got so used to using the floor modifiers, I completely forgot about slope arrows! Not that they would help me with my current problem, but hey.
    2009-01
    466
    I didn't spot the slope arrow command, thanks! Just to be sure, my ramp has flat resting places which I have modelled on a single ramp. Is this fine or is it best practice to model the ramp as seperate sections. I did try seperate sections but found it hard to lock the height of each new section to the last.
    Socrates
    Pittsburgh, PA USA
    1,906
    I'm not sure with a Pad. I don't believe you can have more than one slope arrow heading in the same direction, so the Pad may have to be three pieces. A tip for working with multiple Pads that have to "touch" edges. Put one pad in, and just before finishing the sketch (or come back later and edit it) and select the "common" edge line, and copy it to the clipboard. Finish the sketch, start a new pad that touches, and paste the sketch line from the clipboard, now there eill not be a gap in between the two pads, nor will you get that darned Pads cannot overlap error.
    2009-01
    466
    That's good advice! Should keep me put of trouble
    I'm starting to see Revit as an art more than technical drawing. Sometimes it helps to just hold the brush differently
    Thanks
    Socrates
    Pittsburgh, PA USA
    1,906
    My favorite analogy is that Revit is like the game of chess. Its easy and fun to learn how the pieces are supposed to move. It can take years to really learn the strategy and intricacies of the game.
    Scott
  1. Exfiltration Trench (Trench, Casing, Reinforecement around pipe)
    Last Post: 2013-02-23, 08:32 PM
  2. Sloped Inserts in sloped walls
    By lukec in forum Revit Architecture - General
    Last Post: 2008-08-08, 06:31 PM
  3. sloped floors with sloped levels and stairs
    By sopori in forum Revit Architecture - General
    Last Post: 2007-09-13, 12:15 AM
  4. sloped joists
    By johnf.77896 in forum Revit Architecture - General
    Last Post: 2007-06-27, 08:46 PM
  5. Sloped wall
    By florin_balcu in forum Revit Architecture - General
    Last Post: 2006-03-15, 09:37 PM
