Results 1 to 10 of 20
Thread: Curtain wall butt glazing
    4
    Default Curtain wall butt glazing
    I thought I read somewhere that a new feature in 7.0 would allow glass to butt in corners without a mullion. how is this done?
    Also horizontal mullions are supposed to join better at non 90 degree corners in 7.0 and this appears to be correct but, I seem to be having a problem with the top mullions which are not joining. Any ideas what would be causing this problem. Both walls have the same height settings.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Curtain wall butt glazing
    I've always had to make a special panel family for corner conditions in SSG glazing, I don't know if 7.0 has a built in way to do this. But creating the special panel is very easy, just add an extension parameter to oneside of the panel family and reallign the panel to it.
    Scott D. Brown, AIA
    BECK
    2003-08
    Tijuana
    225
    When you select a mullion in elevation view, Revit displays a control at mullion intersections to select which mullion runs continuously at that intersection. Try to change this at the intersection that causes the problem. This happens often at corners.
    4
    Scott,
    Thanks for the reply but I am not sure I follow what you are trying to say regarding creating an extension and aligning it.
    Carlos,
    regarding your suggestion about the intersection toggle. I do not get a toggle for that end of the mullion since there is no vertical mullion there.
    Any other suggestions to get the horizontal mullions to join would be appreciated.
    Thanks
    John Landry
    Member tmullins68225's Avatar
    2003-11
    Lexington, KY
    21
    Lightbulb Re: Curtain wall butt glazing
    Here is a possible work around.
    I created a new corner mullion based on the Quad Corner Mullion. I set depth 1 & 2 to 1" (matching the depth of the glass). Offset is 1.25" (to match the typical glass offset). Finally I set the Material to Glass.
    While this is not a true butt glaze it does come pretty close to the effect.
    -Tripp
    2003-11
    Lexington, KY
    21
    Smile Re: Curtain wall butt glazing
    Here is a copy of the file to show how it works. I'd be interested to see how others have worked around this as it's a detail I like to use.
    Oh, and file's in 7.0
    Good Luck,
    -Tripp
    2003-05
    Coast to Coast
    4,440
    2
    here is my corner panel family.
    Scott D. Brown, AIA
    BECK
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,611
    Just downloaded and used the ssg panel corner. Thank you. Thank you, Thank you. It solves so many problems.
    2003-05
    Coast to Coast
    4,440
    You are very welcome.
    Scott D. Brown, AIA
    BECK
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    This solution to an old question came out of the blue this evening. Example project and image attached.
    All the best -
    Phil
  1. 2010: Mitered/Butt Glazed Curtain Wall ACA 2010
    By jodi_sherrell in forum ACA General
    Last Post: 2014-04-24, 04:01 PM
  2. Butt Glazing Curtain Wall
    By phyllisr in forum ACA General
    Last Post: 2013-12-24, 10:13 PM
  3. Butt-glazed curtain wall
    By JamesVan in forum Revit Architecture - General
    Last Post: 2012-11-19, 01:52 AM
  4. Curtain wall butt joint glass
    By gerald.untario in forum Revit Architecture - Tips & Tricks
    Last Post: 2010-10-06, 03:58 PM
  5. Butt Glazing in Curtain wall
    By raye in forum Revit Architecture - General
    Last Post: 2006-07-18, 09:24 PM
