Thread: can not load column and framing tags
    2008-09
    136
    Default can not load column and framing tags
    im trying to tag all my columns and beams on a job i am working on and i get a message saying ''no tag is loaded for this type. would you like to load tag now'' but when i try to load the tag i cant seem to find a tag for it.
    i must of changed a tag family or something along them lines because i could tag them on the last job i was working on, its strange because it lets me tag foundation pads
    can any1 help as i have a deadline to meet.
    cheers
    2008-07
    Brisbane (Ex. Swedish)
    346
    Default Re: can not load column and framing tags
    One way to get your framing and column tags in to the project (if you don’t know where they are saved) is to first open up the last project you worked on (as you mention that the tags where OK there).
    Select a tag and go Edit Family on the option bar. Save this tag family. Open your new project and load the tag family in to new project.
    Or if you have both project open at the same time:
    Select the tag in the “last project” you worked on and go to Edit Family on the option bar. Click on Load into project and select the new project.
    Cheers
    J
  1. Framing Tags
    By sjsl in forum Revit Structure - General
    Last Post: 2009-03-18, 10:07 PM
  2. Sloping the Column and framing
    By djn in forum Revit Structure - General
    Last Post: 2007-09-23, 04:47 PM
  3. Difference between Column and Framing Families?
    By CeeVee in forum Revit Structure - Families
    Last Post: 2007-08-07, 01:09 AM
