Results 1 to 8 of 8
Thread: insert barcode to drawing
    2009-05
    3
    Talking insert barcode to drawing
    I was wonder there is anyway we could insert tif file(barcode)?
    our company drawing has barcode attach to dwg file, right now i manually insert(raster image refernce) "barcode" which is same as file name on m_space and making veiwport for that. but it is so many steps to do it. anyone have idea guide me please, by the way I'm not american so you notice. thanks.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: insert barcode to drawing
    If you are just trying to automate the insertion of an image, it probably would not be too much trouble.
    You could also create a typical viewport for your "barcode" in your template file.
    Hi,
    I have the same problem with yeun. But according to your talk, I still have no clear idea about this.
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Simple way: Look at what the command-line options of the -ATTACH command. Next you get the current DWG's path and filename from the DwgPrefix and DwgName system variables (use getvar for these). Then you need to alter the extension to obtain the TIF/PNG/etc. file's path (either use the vl-filename-* functions or extract part of the DWG filename through substr & strlen). Next make a lisp defun which uses these things and then send them to the attach command - if you prefix this defun's name with c: it becomes a new command you can use in the DWG.
    If you wanna draw barcode and generate barcode image, some free barcode generator online can be found, just search in "free barcode generator sodftware".
    2015-11
    Jo'burg SA
    4,512
    You mean e.g. this one: http://sourceforge.net/projects/zint/
    Nice - allows for many different types of coding and saves to PNG/EPS/SVG, but i don't think it solves the OP's (both yeun & Martin) problem. The OP's already got the TIF image file which is to be placed in the drawing. What he's after is a way to insert that more automaGically than ImageAttach --> Browse to File --> Select --> OK --> Click Left-Bottom point --> Click Top-Right point ... for each drawing.
    Basically something like this:
    (defun c:InsertImage  (/ filename found)
      (setq filename
             (strcat (getvar 'DwgPrefix)
                     (substr (setq filename (getvar 'DwgName)) 1 (- (strlen filename) 3))))
      (if (vl-some '(lambda (ext) (setq found (findfile (strcat filename ext))))
                   '("JPG" "GIF" "PNG" "TIF" "BMP"))
        (command "_.ATTACH" found "_Non" '(0. 0. 0.) "" ""))
      (princ))
    problem is solved, thanks anyway~
    2002-01
    jUSt Here (a lot)
    9,105
    Quote Originally Posted by Martin_Brook_1989342426 View Post
    Would you mind letting us know how it was solved?
  1. 2013: Get revision & drawing Number from Drawing insert into word or excel
    By stcy_hennig in forum AutoCAD LT - General
    Last Post: 2013-11-26, 01:35 PM
  2. insert "barcode" to drawing
    By yeun in forum Facilities Management In Practice
    Last Post: 2012-11-20, 04:38 AM
  3. Replies: 2
    Last Post: 2007-05-17, 10:50 PM
  4. Insert block definition from one drawing into current drawing
    By ktisdale.118609 in forum VBA/COM Interop
    Last Post: 2006-08-08, 10:28 PM
