anyone knows how to install stirrups in curve RC beam...
Cut a section perpendicular to the beams.
Place your stirrup- you may need to adjust it manually, but if your section is perpendicular, it should go in correctly.
Use the polar array tool.
Good luck,
Joe
thanks.... is there any other way.... or the best way???
its not posible by sample array, because the beam is sloping...
